Hi.
Am currently doing up my kitchen and wish to ensure the electric supply to my hob are is ok.
Currently, the 6mm gets to my hob via grey box above CU (45a). It powers only a hob at the moment via an isolation switch located in an inaccesable place below worktop.
What i would like to do ideally, is move the switch up to above the worktop and also use it to power a cooker which is a plug and play 13a single fan.
Been informed of this:
http://www.alertelectrical.com/Wiri...asyfit-Dual-Appliance-Outlet-Plate-PRW217.asp
Which im assuming can feed the hob and also a socket fed by short 6mm for me to plug the 13a oven into (located behind the oven).
Is the current setup ok to allow this or do i need to be considering other alternatives?
The other thing to note is that yes the grey box with dolly down does isolate the hob but also the MCB for shower turns it off too!
So, im open to suggestions. Im thinking what i should do is change the grey box for an RCD but again, im not sure.
Advice welcomed.
Advice welcomed.
