I've inwardly digested revised plan 1valveand it wont work
Back to the drawing board I'm off for tea.
Think what the gray wire does and the relationship to the brown wire.
heytesto";p="1225462 said:I've inwardly digested revised plan 1valveand it wont work
it will work as the stat seperates grey and brown
Do not, I repeat do not, link the grey and brown.
The grey always goes to a premanent live.
in this senario it doesn't and does not need to!
The 'HW' and CH channels are independent. If you understand S-plans you will understand this.
we understand this ! you obviously haven't grasped the thread (2 stage heating circuit on an Ecotec combi) nought to do with water and we are discussing using a single channel programmer!
yes your correct, but we are talking about using only one channel - the Heating on and i did say right at the beginning to make sure it was volt free as terminal 1 needs to be fed from terminal 3 on the Ecotec.Read the OP again, Kevin.
The LP241 is a TWO channel programmer.
to confuse you!!why has this been made so complicated!![]()
it just needs to be wired the same as a gravity hw system.
Whatever happens it either needs a 2 channel programmer, a room stat or both.
Is the Eco tec external control circuit volt free or 240v?
Dinners nearly cooked![]()
The grey supplies power to the MV and the brown tells it open, which one supplies the power to the orange.
