For this reason the grey wire needs to go to permanent live rather than CH ON, even though it's only needed when CH ON is live.
We know all that, it why the discussion is taking place.
T3 boiler to Prog T1
T1 prog to bathroom stat common
Grey MV to Bathroom common.
Bathroom call to boiler T4
Prog T4 to room stat common.
Room stat call to MV brown.
MV orange to boiler T4.
The LP241 is 240v only. ie, it doesn't do volt free. Only the single channel progs LP111, LP711, do volt free. In which case you would come off 3 on the boiler to 1 on the prog. However, this is not what he has or needs.
With your method, you will get feedback up the orange wire, down the grey, and into the brown, which in turn will open the valve when it shouldn't.
If the grey wire was connected to the bathroom stat common, the main CH circuit wouldn't work if the Bathroom timer channel was off.
no it won't as there is the small matter of a room stat between grey and brown!![]()
the OP's design was not asking for bathroom seperate only to stop the flow round the rest of the heating circuit. and both stats come from one time source
yes in this senario it would hold until the bathroom stat was satisfied, but the heating circuit would shut down the minute the bathroom was satisfiedno it won't as there is the small matter of a room stat between grey and brown!![]()
But if the room stat was calling for heat then the motorised valve wouldn't let go, if the bathroom stat was calling.
