Im connecting a towel rad to the mains and need to extend the flex. Its 400W. I will be using a 3amp fuse in the switched spur.
The guide on this site suggests i should use a flex sized 0.5mm. I have some 1.5mm flex. Is it ok to use that or do i need to get 0.5mm
A friends place has the same towel rad and her electrician used a 0.75mm flex
Does it matter if you use a thicker flex than recommended in this guide
http://www.diynot.com/pages/el/el003.php
