electric glasswashers
7 Aug 2008
how would you connect a glass washer in a pub its not 3 phase but the cable is to big a diameter for a plug top think its 4mm any suggestions what to use
Most pubs would have a metalclad 32amp double pole isolator, located by the unit.
With a large 25mm stuffing gland for the flex.
Yeah, and you might as well play the lottery this week if you are that lucky :LOL:
so would it be ok to wire it off the ring main the app is 3800w if i put in a isolator
No, it needs to be on it's own radial circuit.
Best call an electrician in.
I think you accidentally typed confidence when you meant competence.
i am just lack of confidence
Although this is rapidly turning into a bash-the-OP thread, I think there's good reason for it. You have just admitted yourself to having a lack of confidence, and what you've said here doesn't exactly inspire a lot of confidence in you either, so perhaps that's a wake up call? If you're really serious about getting this glass washer wired in, you need to employ the services of an electrician.
