- Joined
- 27 Jul 2010
- Messages
- 17
- Reaction score
- 0
- Country
am i missing something or is the current vent of 50% of required free area not 50% of what the manufacturer recommended? if so the boiler has always been "unsafe" but its only recently that the regs were changed to raise the classification to a potentially more serious one. quite rightly IMO. the HSE will probably have raised it due to a death or serious injury. can anyone think why the HSE would have a direct reason to get rid of old boilers? nonsense i think.
off the top of my head the definition of At Risk is a situation that could cause danger to life or property. it's the engineers opinion based on a particular regulation. if you don't agree with that engineers opinion then get another.
IIRC the 90% of free area figure is acceptable because it takes into account the possibility of measuring errors.
The current regulation ( 1st June 2008 ) requires 90% of the ventilation stipulated by the manufacturer.It was previously 50%.
If an engineer decides that an installation is AR, in this case if ventilation is less than 90% of the boiler manufacturer's recommendation, he should ask permission to turn the boiler off. At risk surely refers to the possibility of a problem at some unstated future time such that corrective action must be taken before the boiler is turned on again. It can hardly be a matter of opinion because a precise measurement is given. A registered engineer should have no problem checking this. Otherwise how many opinions do we need ? AR is not a matter of opinion; it is a failure of an installation to meet a required standard,
