If you really don't want the FCU in the house, what about putting it on the outside of the house wall instead of the plastic box?
What's wrong with an FCU in sight? We're talking something like this...
Not something like this...
With it inside, make it a double pole FCU and you can easily isolate the external installation if, say, a fault occurs (eg water ingress) that trips the RCD on your socket circuit and doesn't let you reset it. Surely putting the FCU inside is less more difficult than all the extra external wiring with the FCU in the garage?
But like I said there are two beams running down each side where the existing socket metal box is situated. Then I have to find another beam to attach the FCU's metal box to or find one that is running horizontal... I'll end up destroying a patch of plasterboard to find a suitable location.
Thanks for that flameport. This is another possibility I would choose, but do you think the 1 x 1.5mm SWA cable will be a b*****r to attach to it (plus the hituf cable for the other socket)? As I need to use SWA to be buried.
Mate mate mate mate MATE! You are making things much more awkward (and expensive) than they need to be by your insistence that the FCU can't be fitted indoors.
If your decor and wall type make it such a struggle how about:
1) Surface mounted? Not the prettiest, but not the end of the world.
2) If the existing socket is a single, just replace it with the FCU? Yeah, you'd lose a socket, but hey.
3) If it's a double, remove it and the double backbox, slightly hack out the opening in the plasterboard, install a dual back box and fit a single socket and the FCU. Et voila!
So the battens on this wall are so close together that a socket fits inbetween and no room for the FCU beside it? It could always go above or below - that's an option. Or if it was to go on the other side of the nearest batten, if you cut the hole in the plasterboard for the dry lining box very close to the batten, you could probably poke a drill through the batten so you can fish the cable through from the socket to the FCU. Or just cut a channel of plasterboard out, notch the batten, install the cable and repair the plasterboard. All easier than giving yourself a load of extra wiring to do outside.![]()
Hi mate, thanks for the advice. Now that is an option I wasn't aware off !!!
3 is definately an option, it is a double socket and I'll go for thatYes you are right about costs, the outdoor FCU is £30 alone, it is quite alot really
25mm wider, but that is no problem! I can fit a switched FCU too!
Rhetorical question of course Rice.
Of course he doesnt even think about testing. Or Part P. As long as it works when he switches it on it must be OK.
Trouble with these sites - on the one hand at least people are asking for help and might take notice of advice given on the other hand it purely encourages more DIY bodges.
Well more "advice" yet still no mention of how this DIYer is going to test his work to ensure it, or any part of the installation that he is connecting to, gets anywhere near complying with BS7671 and similarly no mention of any intention of notifying this work to Building Control under Part P.
A competent registered sparks will do both.
Cowboys do neither.
Ross on Wye or Ross in Rosshire - it still needs testing - which of course isnt going to be done.
Another page of advice on and you still ignore the need to test - or are you happy that your neon screwdriver is a good enough tester?
No problem Morg, glad I could make things a bit easier for you!![]()
Have you used SWA cable before? If you're not used to it, it can be a bit tricky to terminate. Here's an excellent guide, and I recommend you get an extra gland or two and practise on a spare bit of cable before you go for it.
