A thing (consumer unit) of beauty!
The earth cable isn't supported.
The bends in the tails look a bit sharp.
The earth cable draped over the board below the CU looks a bit untidy.
You didn't make good the paint on the wall before you put conduit in the way.
And is the T/E going into the 2nd from right conduit grey, or dirty?
no spare capacity in the conduits, should have installed more empty ones..
and all of that for 1 new circuit?
It looks ok to me, however!
I would have grouped the RCBO's together.
Also you need a periodic inspection label :wink:
Did you use a grommet/similar where the tails enter the board?
I don't like the way those blue RCBO neutral leads go over the earth cables of the 32 amp circuits.
It makes ring continuity testing and the like more difficult.
Change it.
I don't see any of the old wiring that would have been in the old Wylex yet.
Have you extended them?
The one under the CU? I have purchased clips and they are on their way to me as we speak.
Agreed, 25mm tails are a bugger to get pretty.
Is either going to be upgraded or moved depending on gas meter relocations costs.
Will probably end up being covered by full height kitchen cabinet.
Grey, added new socket to ring in bedroom.
Think that was sticker my son attached to his bike! CU came with a grommet strip that you cut to length.
