It bothers me that some experts dont recognise VIR![]()
Ditto for using the abbreviation VIR!![]()
Regards
Just a prediction of people complaining about your use of the term "earth bond"...What's your point?![]()
Just like the cables from the CU could be joined to old wiring shortly after leaving, so could the cables from the sockets, you need to get it all properly checked out.I've checked all my wall sockets, they have the same modern wiring as that coming out the trip board. However, the light switches are once again the old wiring.
They look like plastic switches with no earth terminal. If so then they don't need earthing.More worrying for me, the previous owner installed dimmer switches on these lights (which have metal turn dials to switch on/off), as shown in the photo below :-
Or possibly the whole lot, depending on what the inspection uncovers.I prodded around the ceiling rose but could not find an earth wire tucked away anywhere, so have to assume it just doesn't exist.
So I guess its time to get the lighting rewired.
SUNRAY";p="1758693 said:Ditto for using the abbreviation VIR!It bothers me that some experts dont recognise VIR![]()
Not what I meant, it's Vulcanised Rubber Insulated Cable, it's the rubber that's vulcanised! VRI cable, not VIR although it's in common useage, it's wrong, as with plugtop, it's a plug.Apologies for using an abbreviated description for:-
Waxed cotton covered vulcanized indian rubber insulated wire.![]()
Never heard that term in use for cable, cord yes - cotton covered.In my experience, some electricians of the era called it cotton & rubber, reserving VIR to describe rubber/rubber construction, ie single tails, twin, T&E etc.
Note the cotton sheath is not classed as insulation, it was a later addition to prevent the rubber insulation perishing by keeping the air away and protect the rubber against damage during installation and compression damage once installed.
Agree with that, it's the reason why this had to be cut back aboout 1/2 inch in old money, to avoid contact with the terminals.
Regards
densamember";p="1758769 said:Ditto for using the abbreviation VIR!It bothers me that some experts dont recognise VIR![]()
Regards
I'm fine with all of this, and freely accept that there are regional, trade ETC variations in 'slang' terminology however I don't believe I have ever heard it referred to as VRI [AFAIC thats a variable reactance inductor] so I have just done a quick google search, VRI came up with 33,000 results and vir came up with 1,300,300 results though I did not look at any of the results to see what they are or which is the more correct.
I agree that plugtop is wrong and even worse plugsocket. I hate it when I hear electricians using the terms and will not use them myself.
This is sent as a friendly discussion
