Should the water in a plastic lined garden pond have an electrode to provide a path to ground from the water ? Are there any guidelines for this in the regulations.
From a discussion group
I followed this up. The RCD protecting the socket it was connected to did not operate. It did operate to the test button. After retrieval the motor was found to be saturated so water was definately in contact with the wiring.
Experiments with a neighbour's pond which has a butyl lining found the impedance between water and ground with 50 volts DC applied is over a Meg ohm. The ground electrode was about 2 feet of 15 mm copper pipe as earth rod in damp soil about a yard from the pool edge.
This suggests to me that while the blower wa in the pond there was no signifcant earth leakage as the water appears to be insulated from ground. I can see the water's potential being about mid way between Live and Neutral, about 115 volts above ground. This suggests a person kneeling on wet ground and putting a hand into the water could receive a serious electrical shock while power was still applied to the equipment.
YES I accept that common sense states turn off power and remove plug from socket before attempting to recover the equipment but not everyone has that common sense.
When my garden leaf blower was dropped into the pond it continued to run under water until the plug was removed from the socket. I was told the power would have been turned off automatically if that happened
