I was going to post the following in DIY disasters but there is a serious point in the following - and a good indicator of why untrained people should not play with electrics!!
Back in 2001 I moved into a chalet bungalow with my wife, it was built in the 1930's as a traditional bungalow but had a large loft conversion added in the mid 1990's. Not long before we moved in the upstairs ensuite was refitted with some fitted units, lighting board above the units, new power shower, new sanitryware etc. The owner did it himself but I have to say quality was excellent.
All was well until a couple of weeks after we moved in - I walked out into the porch where the fuseboard was and noticed one of the breakers had popped. Not being sure of why I popped, or what it powered I reset it and thought no more of it (just assuming that it was a bulb blown somewhere, or other such minor glitch). Anyway 6 months or so passed and I decided that due to lack of storage space I would board out the loft so up into to small loft in the apex of the roof I climbed. You couldn't stand up but it was an OK space for storing cases and the like.
I started to press the insulation down (whilst on my hands and knees) to make sure there were no wires crossing joists etc before I put some flooring chipboard down when I put my hand on a cable.
Unfortunately the cable turned out to be the feed for an old electric shower that used to be in the ensuite before it was refitted and changed to a mixer bar. Even more unfortunately the end of the cable had been pulled up through from the ensuite and left with bare ends - the other end terminating at the breaker that I had reset some 6 months earlier!! All I can say is I don't remember what happened next but my head hit the roof so hard it broke two roofing battens and smashed two tiles on the outside of the roof, I cut my head open, my right arm was dead for a few hours and the fillings in my teeth ached for days!
In the cold light of day it appears that the power had been 'disconnected' by popping the breaker and the wire left coiled up in the loft. The breaker must have been popped when we moved in, but by not noticing I had assumed it had only just popped when I saw it. By resetting it I made the cable live and then months later I uncover the live end with my right hand.
Had I been older, infirm or a child I could be dead now but by luck I seem to be made of stronger stuff.
In some respects amusing and probably worth £250 on a home video show but equally potentially lethal and caused by a homeowner cutting corners/not appreciating what he was doing.
For this reason and this reason alone always get a professional in if you aren't sure what you are doing!
There endeth the lesson
