Unless the ceiling is a fire compartment barrier he doesn't need firehoods.I use a plant pot too, but Screwfix do intumescent hoods - 70589.
Expensive for what they are but you do need something.
John![]()
John![]()
He doesn't need an electrician.Waste your money if you wish OP! Many people will have used the clay plant pot method, but if you wish top get an electrician please do so, but I can quarantee he will erm and r, and then say 'you need me to do this for you ...', for which he will charge a fortune to install and your protection will be no better.
He does need somebody with a bit more sense than you advising him though.
react to fire to close off the hole in the ceiling.intumescent hoods
very interestingreact to fire to close off the hole in the ceiling.intumescent hoods
The plaster board contains the fire in the room long enough to enable people to leave the room above before the floor starts to burn.
Cut holes in the ceiling and the fire goes up through the hole and the joists and floor boards start to burn. Smoke gets into the room and people may die from smoke inhalation before they wake up
Smoke and flames into loft are just as dangerous.
Your choice as to how to stop fire going through the hole(s).
No - what you need is a completely sealed box large enough to provide the clearances specified by the manufacturer.i had a look at the screwfix thing
it looks odd
i thought it would be VERY important to have full ventilation because of heat build up?
aah... funny u mention thatTo be honest I would use LED lights nowadays. They give the brightness and are lot more energy efficient, without the issue of heat being a concern.
great replyNo - what you need is a completely sealed box large enough to provide the clearances specified by the manufacturer.i had a look at the screwfix thing
it looks odd
Full ventilation = a full path for warm moist air to get into the cold loft where it will condense and rot the roof timbers.
Full ventilation = a full path for warm air carrying the inevitable dust etc to rise upwards to the same places all the time, discolouring the ceiling.
Full ventilation = a full path for cold air from the loft to fall down into the rooms below when the lights aren't on. Most people term that sort of air movement "a draught".
- http://www.nhbc.co.uk/NHBCPublicati...ical/StandardsExtra/filedownload,16553,en.pdf
- Pre-formed cap to seal downlights: http://www.aico.co.uk/downlights-in-loft-space-what-to-fit.html (It's NOT a firehood....)
- IET article on installing downlighters safely
well... funny u mention thatLED lamps are like work.
Good ones aren't cheap, and cheap ones aren't good.
i'm talking to a large seller in china about selling these online
i know this might be going a bit off topic, but how would you say u determine ones that are 'not so good'?
awesome - i didn't know about them.Buy from a reputable wholesaler if you can, like CEF.
