- Joined
- 17 Aug 2010
- Messages
- 2,888
- Reaction score
- 506
- Country
Although it's worth saying FWIW that not all sockets have a double pole switch.
True, but that's an easy fix.Although it's worth saying FWIW that not all sockets have a double pole switch.
A socket with a DP switch providing 3mm separation should be available. However, I presume you are talking about using a plug with the socket, and I imagine one might struggle to safely terminate/isolate the 'pilot wire' within a plug, wouldn't one - even getting a bit of 2A connector block in there could be a fight?Fair cop. These are the MIs
The heater is fitted with a length of flexible cable type H05VVF size 4 x 1.0mm2 for connection to the fixed wiring of the premises through a suitable connection box positioned adjacent to the heater. The supply circuit to the heater must incorporate a double pole isolating switch having a contact separation of at least 3mm.
Could that be a socket?
Ah - good pointI'm pretty sure you'll acheive DP isolation with more than 3mm of seperation if you pull the plug out![]()
Do we know what the fourth core is for?
This heater has four core cable with normal line, neutral and earth plus a black pilot control wire. The black control wire is designed to carry a signal from slot in or wall mounted Dimplex programmers.
If, however a programmer is not being used, the pilot wire should be isolated.
Isolating the cable be achieved in both plug or backbox of course, but for me common sense says use an fcu.
The MIs say:Do we know what the fourth core is for?
No argument with that - but that isn't the issue. How/where are you going to terminate the fourth (potentially live) core?A BS1363 plugtop will acommodate 2.5mm² in each terminal.
Yes.Anyway, would you be happy that such an arrangement complied with "connection to the fixed wiring of the premises through a suitable connection box"?
Kind Regards, John.
This is a genuine, not rhetorical, question. Do you think that wrapping with tape would comply with (per MI):It is very small and would be safe if wrapped with self-amalgamating tape.
Yes. with S.A.T (and/or heat-shrink if you want) - there will be no copper exposed except the csa.This is a genuine, not rhetorical, question. Do you think that wrapping with tape would comply with (per MI):It is very small and would be safe if wrapped with self-amalgamating tape.
Presumably the same as any other conductor in an enclosure (the plug).I'm not too sure where to looks in the regs for that one!
- If, however a programmer is not being used, the pilot wire should be isolated in accordance with the current IEE Wiring Regulations.
True, as far as risk to people are concerned, but it's obviously got to be safely insulated from other conductors/live parts within the plug, for those ocacsions when it is plugged in and live.If it's terminated in a plug there will be no issue as to gain access to the exposed end you're going to have to remove the plug so there is no way the wire will be live.
So it seems/looks. This is one of my greatest frustrations about participation in this forum - and, I suppose, one of the things which I'm tiring of a bit. If you knew me 'in private', you would understand how different I actually am from the way I appear here, and how different would be the things I would say (and do) in a non-public context.As usual we are going round and round in circles for the sake of it.
