Curtain rail over concrete lintel
  • Thread starter Thread starter danroach
  • Start date Start date
D
danroach
Hello.
Just had my sons room replastered. There is a gigantic concrete lintel over the window and in the past, attempts to drill into it have proved futile. The previous owner of our house had glued a piece of timber above the window and screwed the curtain rail fittings into that, which, while not looking particularly slick, did seem to do the job.
I wondered if anyone had any advice? I've resigned myself to the fact that I might have to do the same as the previous owner but thought I put a post up on the forum before I went ahead.
Thanks in advance,
Dan
You can drill but requires a SDS drill, or you could glue a sheet of timber under the reveal and decorate to match walls then use the edge of this to screw brackets too, less obvious than a timber externally.
