No. As I said, the practices are inherently unsafe - otherwise there would be no need for specific training, authorisation and PPE in order to mitigate the risks.
Apply a little extension to that argument and we should immediately do away with dangerous lectrickery altogether. After all, part of electrician training is procedures for safe isolation etc - so (near enough) "specific training, authorisation and PPE in order to mitigate the risks".
And for those who've ever worked on a system with fuses in the "fuse board" - when you isolate a circuit, do/did you insist on switching off power to the whole house before removing/inserting a fuse ? Or do/did you do what everyone I know does and just pull/replace the fuse "live" ?
Flipping the argument on it's head ...
So the DNO fits a switch upstream of the cutout fuse. Where's your point of isolation for that switch ? Another switch upstream of it ? Not to mention the fuse required to protect it. Clearly this would be nonsensical.
And each switch is another point of failure.
IMO there is nothing wrong with the DNO approach. The risks are well known, and controllable by working methods and PPE.
But back to the original petition.
Personally I think it's the wrong approach. If it were made a condition on the DNOs that when they do work on a supply that they need to provide a means of isolation available to the end user (or at least a qualified electrician) then that would deal with the issue once and for all within the next meter refresh cycle. Some designs of meter do in fact include an isolator switch accessible once the load side terminal cover is removed - I cannot believe that the inclusion of such a feature would add more than pennies to the cost of a meter in the volumes they will be bought over the next few years.
Such a condition could be imposed by a variation in their supply licence which will set out certain things they are required/allowed to do. it wouldn't require any primary legislation or even a statutory instrument.
A to the remote turn off facility ...
I really, really cannot see this having been removed from the specs. It's always been an integral part of the meter design (don't forget there are facilities in all the meters to operate in pre-payment mode). Given (as pointed out) our impending lack of surplus generating capacity, I reckon it's going to get used in anger before too long. Give it 5 years and I don't think we'll be able to cope with a winter like we had just under 2 years ago. IIRC back then we had a very small margin between capacity and demand - and we've got something like 8GW or nuclear, and 16GW of coal likely to be going off line in the next few years. Hmm, those windmills aren't going to make up for a 20+GW shortfall when there's no wind.
