Even if they could do it without entering the property, I suppose there would always be occasion where they may have to.
Why don't you want them to enter the house?
Triffids in the loft/conservatory/kitchen!!Why don't you want them to enter the house?
Thanks. That's interesting. I obviously can't disagree with it in terms of safety, but it does beg the question as to how far someone changing a meter (or, indeed, a DNO doing more extensive work upstream of the meter) is expected/required to go in verifying the safety of the customer's installation downstream of a correctly-provided supply and meter.YES Whatever the condition is prior to the work it must be correct when finished. Staff have been dismissed for incorrect polarity, it is potentially that serious. See my earlier post there has been at least one death to a child as a result. The CU idea is a red herring, polarity must be proven before re-energisation, no ifs, no buts, no excusesThere obviously still could be a persisting (pre-existing) polarity reversal within the house (e.g. at CU, or at individual sockets etc.), but is that 'of concern' to those just carrying out a meter change?
Thanks. That all makes sense - although, unless you check at all sockets (one on each final circuit, at the very least) that method would obviously be limited in its ability to detect polarity errors in final circuits. I can say with almost complete certainty that such testing was not undertaken at my last two meter changes, since I (undoubtedly annoyoingly!) watched them like a hawk! Do I take it that the polarity checking is meant to be undertaken after meter changes (which is the topic of this thread) as well as after DNO work upstraem of the meter?The test is done with a plug in tester at a 13A plug. If it is found to be incorrect further investigations would take place to find the source of the problem. If it is on the customer's installation (but don't forget a check would be made before) the supply would be left disconnected until the fault rectified. If on the metering or the supply, obviously it would be corrected.
Fair enough - but that's obviously something which could happen any day, to any installation. It obviously is 'better than nothing' for a DNO to check for such things whenever they have an opportunity, but it is so rare for them to be within a customer's premises that they will clearly miss the great majority of such consumer-side errors - at least, until they have been present for a very long time!The death was as a result of an electrical contractor breaking a meter seal to change a CU and re-connecting it incorrectly (pre 17th edition). One I know about as it occurred within my DNO's patch.
In the context of this thread, they could confirm that the work they have done (changing an external meter) has not resulted in a change in polarity of the supply going into the house, without entering the house or undertaking any checks/tests therein.but surely you agree it is reasonable for them to carry out this most basic and simple of checks, when they are already at the premises and have just disconnected and reconnected?
Indeed, but my point was that, on the basis of the (accessible) meter terminals (and tails attached thereto), it is possible to confirm that the polarity entering the house after they have done their work is the same as it was before - which presumably goes a fair way down the 'CYA' path!Given that all there is to check on are the meter terminals, this is not the case otherwise we would not be requesting entry to check.In the context of this thread, they could confirm that the work they have done (changing an external meter) has not resulted in a change in polarity of the supply going into the house, without entering the house or undertaking any checks/tests therein.
Yes, I realise that - hence my earlier comments about what can/should reasonably be done, given the myriad of dangerous things which might be going on within the installation.The check on the3 customer's installation is more of an add on.
Whatever, it appears not to matter why.Im having my meter changed from an Economy 7 meter to a standard meter since we haven't had Economy 7 storage heating for over 20 years since our village went to oil (we have no gas!).
The electrical company are insisting the engineer may need access to the house and I asked why as the meter is on the outside of the house.
They wont say why. I think it must just be standard customer services bull$**t.
Can anybody offer any explanation?
Oh, I see, that explains it, then! Do I therefore take it that these people are only trained/trusted to plug testers into sockets and therefore would not be allowed to test polarity at, say, a CU? What sort of/how much training do these people have - I have in mind that even 'minimally trained' electricians (or apprentices) undertake potentially 'live tests' every time they 'test for dead' - which must happen thousands of times every day.no because that requires the meter terminal cover to be removed whilst live which most meter operatives are not authorised to do, connect leads to live equipment that is not designed for that purpose. If it could be done do you not think we would be doing it?
