My boiler keeps tripping out.
Attempts so far:
I have just cleaned and serviced the main parts inc replace nozzle as per manual.
I have found the problem to the tripping out oil is not getting to the nozzle reliably. Only way to get the boil to fire up is to loosen the connection to the burner to release the pressure in the line and tighten as soon as the valve on the oil pump opens and the boiler will fire perfectly.
so in my mind there are two possible culprits:
1) check valve - I did look at it in the service and holes are clear. do they become sticky? or eventually fail? I cant find a diagram of the internals but I think its just a sprung ball bearing based valve
2) oil pump pressure not quite high enough to open check valve (nothing here has been touched in terms of pressure regulation valves and don't have the kit to check air ratios after so not intending to go alone on this.)
So my question:
Is it worth changing the check valve or is it unlikely to have failed and more likely to be down to the pump pressure or early pump failure
Attempts so far:
So my question:
