- Joined
- 11 Jan 2004
- Messages
- 46,712
- Reaction score
- 3,927
- Country
So your so called spark's 20A radials are pure fiction!
That makes them pretty fictional, because the only thing which makes a '20A radial' a 20A radial is the 20A MCB! From what you have described, what you appear to have are 32A radials (radials protected by a 32A MCB) wired with 2.5mm² (rather than the required 4mm²) cable!There is nothing fictional about his 20a radials other than there is no 20a mcb.
That appears to be what we have been told ...So coming from the breaker on the left are 2 radials, not a ring? ... If so the "electrician" has committed a criminal offence.
Absolutely certain one is literally right next to the CU and the other he has removed from the old ring circuit (existing for the rest of the house) and then joined in the junction box as a radial circuit. All on 2.5mm2Are you absolutely certain that those two 'radials' aren't joined, creating a ring? Do I also take it that the wiring is all in 2.5mm² cable? If so, those two radials on a 32A MCB are seriously non-complaint.1 radial circuit containing 3 x twin 13A socket joined in junction box to 2 x twin 13A sockets + 1 x switched & fused extractor hood. ... On a separate radial circuit 1 x twin 13A socket. .. These two radial circuits are wired to 1 x 32mcb labelled 'kitchen sockets'
It is criminal as is. Or does it only become the offence of criminal negligance if there is a event ( fire, injury, fatality ) as a direct result of the work being non compliant.If so the "electrician" has committed a criminal offence.
Nor, of course, would it be particularly 'good' if one had to wait until someone was killed/injuried, or property destroyed, before one could bring criminal charges. I'm no lawyer, but it would seem ridiculous that the law would allow, for example, someone to construct a very dangerous building yet not be guilty of a criminal offence until some catastrophe occurred as a result.It is criminal as is. Or does it only become the offence of criminal negligance if there is a event ( fire, injury, fatality ) as a direct result of the work being non compliant. It would not be good if any accusation of a criminal offence was made when the work in itself was only negligent.If so the "electrician" has committed a criminal offence.
