I suspect that there is at least some room for debate about that but, for the time being, I'll assume that is the case. Would you say the same if one was only modifying an existing circuit (rather than 'installing a new circuit')? I ask because I presume that there was previously a kitchen sockets circuit, in which case maybe the recent work has been a 'modification' of what was there before, rather than a 'new ciorcuit'?You are not forced to bring the rest of the installation upto current regs, but the part you install must comply. Connecting a new circuit into an existing board with an upfront RCD will leave your new curcuit not compliant.
