- Joined
- 11 Jan 2004
- Messages
- 46,649
- Reaction score
- 3,894
- Country
Have you ever seen a socket wired like that before?
No.How about (preferably without 18 quote tags) when the totally clueless poster comes on here with pics, and then are gently guided as to where the wires should, in fact, be placed?
The point should be to educate, to promote learning, new skills etc.Surely that's the whole point of the diynot forum?
If they cannot, or will not, learn about, and come to understand, the things they want to fiddle with then they should not fiddle, nor should they be encouraged or supported to do so.Other times, they just need helpful and courteous advice that will help them achieve the best and safest result.
No, but that's the sort of thing which can happen when the clueless fiddle with things they don't have a clue about.Have you ever seen a socket wired like that before?
I've said it all before, but ... It is easy to sympathise with BAS's views and motives. However, if one feels like that, the only logical course would be to close this forum (and all others like it) and probably also campaign for the outlawing of all electrical work.We try to guide most visitors in the right direction. ... I guess you are going to claim you are offering nothing but help in the form of links to good reading etcetera. ... But in reality, you scare many away.
Probably "just read the words I have written, and not choose to invent things I have not written and then blame me because you don't like what you've chosen to invent"Sadly, I can probably guess what your response to that will be too.
Nonsense - the thing to do is to campaign for the acquisition of knowledge.It is easy to sympathise with BAS's views and motives. However, if one feels like that, the only logical course would be to close this forum (and all others like it) and probably also campaign for the outlawing of all electrical work.
I don't really think that it needs a "long time" of studying to learn how switches work, or the difference between L/N/E etc.I can't believe that many of us can seriously believe that any appreciable number of people will go away and spend a long time studying and acquiring test equipment etc. before they change their light switch, install an extra socket or whatever.
Very rarely do I do the latter.BAS is by no means the only person here who sometimes says, suggests or implies that an OP does not have (and probably never will have) the knowledge and/or skill to undertake the work their are proposing or asking about
Encouraging and assisting people to acquire the understanding of what they are doing is of positive help.However, for those of us who decide that we do wish to answer some questions, and gives some advice, it makes sense that we should do so in a manner which (in reality) is of positive help to the OP.
That's probably a large percentage of "electricians" on the dole thenNobody should be given, or follow, instructions to put-this-wire-in-that-hole so that they can do things without actually understanding why.
GENUINELY understanding.
Quite so - although I imagine that, even today, the majority of electricians have learned enough 'rules' so as to be able to work pretty safely. However, many of us have bemoaned the fact that, compared with the past, there now seems to be much less emphasis on understanding of 'basic principles' (both of theory and practice) in the training/education of so many people these days, including many electricians.That's probably a large percentage of "electricians" on the dole thenMy experience is that a lot of "qualified" electricians do not genuinely understand the subject - they just follow a set of rules. Just picking a topic at random, I doubt if many electricians at all "genuinely understand" either how an RCD works or the physiological effects on the body of electric currents. They just follow a set of rules/guidelines/standards that says to fit "this type of device in this situation".
Opinions/attitudes/approaches obviously vary but, as you will be aware, that is essentially my view.I'm with the others, you need to assess each case on it's merits. You may be correct in your attitude, but the reality is that in many cases it's better to be flexible and persuade someone to take some help than to be inflexible and persuade them to never ask for help again. If someone "is going to do it" then telling them not to isn't helpful - trying to get them to do it in a more safe manner is.
That's not quite true.A few days ago someone posted asking for help understanding AC. Apart from ridiculing the username there were few replies. I wonder why?
Please explain the situation in the Middle East.
