I think you must have - that's not 'putting a bit of customer's equipment in the meter box' - it's an almost complete takeover of the boxI guess I've just been lucky in the past then!
I think you must have - that's not 'putting a bit of customer's equipment in the meter box' - in an almost complete takeover of the boxI guess I've just been lucky in the past then!
I doubt that you're going to find anything remotely as small as the KMF - I think they're great!So anyway, are there any smaller Metal clad fused swiches, or is a KMF + adaptable box my best bet?
There's a slit cut between the holes using a hacksaw blade.you appear to have the tails exiting through different holes in the metal box?? Or have you just removed the whole of that side of it?
I dare say this is going to get me some flack, but what the hell .... given that ordinary meter tails up to 2 or 3 metres are accepted without any protection, one might consider going in ordinary tails from the KMF into the house (maybe ony a metre or so, maybe even less) into an adaptable box (or whatever) and do the rest of the run from there in SWA?
Not from this side of the room.I dare say this is going to get me some flack, but what the hell ....
He's providing a KMF, so the cable will be protected.given that ordinary meter tails up to 2 or 3 metres are accepted without any protection
I can see the benefits of doing that, but finding a terminal block rated at 100A (80A if using a genuine MEM 800KMF) might be tricky, unless a Henley was used.one might consider going in ordinary tails from the KMF into the house (maybe ony a metre or so, maybe even less) into an adaptable box (or whatever) and do the rest of the run from there in SWA?
Not beautiful, perhaps, but it would only have to be a box/enclosure. I was just thinking of ways of saving even morte space in the meter box - although, with the KMF, you'll have no lack of that, anyway.Hmm, That was a consideration, but then I'd still need to join them, which would need to be accessible, so what ever happens it isn't going to be "pretty" inside.
There certainly are possibilities, and a traditional Henley (not some of the massive 'equivalents'!) would perhaps be the most obvious (and quite small).I can see the benefits of doing that, but finding a terminal block rated at 100A (80A if using a genuine MEM 800KMF) might be tricky, unless a Henley was used.one might consider going in ordinary tails from the KMF into the house (maybe ony a metre or so, maybe even less) into an adaptable box (or whatever) and do the rest of the run from there in SWA?
And in that state if that cutout were ever to go faulty we would not be able to work on it live owing to the presence of all that earthed metal!
That makes total sense. However, although everyone seems to have been talking about metal adaptable boxes (or metal diecast boxes in the case of Bernard), I see no reason why the box used for terminating the SWA could not be plastic (and small) which, together with a (plastic & small) KMF800 would, I presume represent no hazard to people working live in the box.The hint there is that we would really not want any metalwork introducing to a viewing cabinet be it in the form of switchgear or terminating boxes. I know that it is not written anywhere but it does introduce hazards when working on cutouts that are unacceptable to some.And in that state if that cutout were ever to go faulty we would not be able to work on it live owing to the presence of all that earthed metal!
There would also be no reason why technically, you could not provide the earth for the SWA from the other end of the cable and use a plastic stuffing gland at the meter box end.I see no reason why the box used for terminating the SWA could not be plastic (and small).
Yes, also true. I confess I'd overlooked the possibility that an SWA gland in the cabinet could come to represent potentially hazardous (to anyone working live) 'earthed metal' if the shroud were to slip. I suppose that another option (taking up a bit more space) would be to have an SWA gland totally within an insulating enclosure (or, indeed, {some will probably scream!} to terminate the armour of the SWA within such an enclosure without using an SWA gland)There would also be no reason why technically, you could not provide the earth for the SWA from the other end of the cable and use a plastic stuffing gland at the meter box end.I see no reason why the box used for terminating the SWA could not be plastic (and small).
How does the DNO do it when they move meter positions to outside?
Given that the DNOs are not involved even with the meter, I would have doubted that they would be prepared to get involved with anything downstream of the meter - at least 'officially'. What DNO personnel may, themselves, be prepared to do ('for a cup of tea') is perhaps a different matter.Though not the DNO's responsibility, can they not provide suitable fuse and switch? Their equipment can vary from place to place, so do they have something suitable than can be wired in, if the op leaves an enclosure with an Isco block in it?
