Indeed - but, as has been discussed, the correct use of terminolgy cannot by any means always be assumed.A LED element ( just the light emitting diode ) must be supplied with a controlled current. An LED lamp will be an LED element with some means to control the current through it when a voltage is applied to the lamp. ... Putting a voltage source with uncontrolled current directly to an LED element will almost always damge or destroy the element.
Indeed - that is precisely what one would expect. Up-market LED lamps may have a constant-current controller (rather than just a resistor) within them, but if they are described as "12V" (or 24V, or whatever - or maybe even something like 12V-50V, if they containing a constant-current controller) it's difficult see see what that can actually mean other than that they will work off a simple (essentially constant voltage) 12V (or whatever) supply.I would say that you just need a 12V supply. As most LED's are simply a diode that glows, they usually require a potential of between 1.8 and 2.2V. If these are cheap and from china, I suspect what you are getting is a diode and resistor in the package and not much else. I would think a true "driver" or constant current source would not be needed as the resistor value SHOULD have been calculated to keep the current correct at 12V.
Glad they were able to confirm that. As I said, it was pretty difficult to understand what else they could have meant by "12V".Got a reply from the seller, and they have stated that a simple 12v DC supply will be OK.
Provided that they are not miles apart (which I doubt), there's no reason why they can't all be run off the same (simple 12V) power supply. As you said in your initial post, a 20W (or 2A) 12V power supply would be more than enough for all four. Did you ascertain from the manufacturer whether there is a 'driver' (current controller) which has to go between the power supply and each lamp (or whether that is contained within the lamps?) - your electrician will certainly need to know that!Going off at a bit of tangent I know but I'd be grateful for a bit of further advice as I want to supply the correct power supply to my electrician. As I have 4 of the lights, what would be the best way to supply power?, do I need one transformer for each light or can they wired of a single transformer?
You should have him provide all of the materials and equipment. You won't get any form of warranty for his work otherwise.Going off at a bit of tangent I know but I'd be grateful for a bit of further advice as I want to supply the correct power supply to my electrician.
The OP appears to have already bought the lamps, and quite possibly also associated 'drivers' with them, - so I think most of that horse has probably already bolted.You should have him provide all of the materials and equipment. You won't get any form of warranty for his work otherwise.
