Still waiting to find out what going near Fukushima has to do with whether we install new nuclear in the UK.
'Someone' said...
Parts of the area of Fukushima area are unsafe at the moment.
So maybe you can tell us the safety history of all the nuclear power plants currently operating that are of the same design as the one proposed at Hinkley?
What's that I hear you mutter?...There are no current nuclear power plants of that design in operation?
And you must be aware that the first similar one of these due to go into operation is massively over budget, and years behind schedule?
You must also be aware that EDF is swamped with litigation due to it's lack of H&S, cheap labour usage, and financial fraud?
And then of course you are also no doubt aware of the construction 'irregularities' which puts the whole 'spent fuel' storage facilty at risk?
No doubt you will also be aware of the fact that EDF officials were jailed for espionage, particularly of Greenpeace?
You know f*ck all of the risks wobs, and keep spouting the usual automated b*llocks that governments and their corporate masters do...
Give us a reason to believe that a more modern design is going to be less safe than an older design. The truth is that engineering strives to make things better, and that includes safety. Modern reactors already have passive safety mechanisms built, and even UK plants built pre-3MI has been deemed safe including Hinkley B:
http://www.edfenergy.com/about-us/e...ration/documents/hunterston-b-stress-test.pdfThe “stress test” is defined as a targeted reassessment of the safety margins of nuclear power plants in the light of the events which occurred at Fukushima: extreme natural events challenging the plant safety functions and leading to a severe accident. The technical scope of the reassessment is concerned with an evaluation of the response of a nuclear power plant when facing a set of specific extreme situations.
An EU Stress Test report has been completed for each station and submitted to the Office for Nuclear Regulation (ONR), the UK independent nuclear industry regulator: This is the EU Stress Test report for Hinkley Point B.
This report is focused on the adequacy of design basis protection for infrequent external hazards. Infrequent external hazards are assessed as those with a frequency of occurrence of 1 in 10,000 per year. All references to design basis in this report should therefore be interpreted as meaning a hazard with this return frequency unless otherwise stated.
This EU Stress Test Report concludes that there are no significant shortfalls in the safety case for all the UK power stations operated by EDF Energy, and that it is safe to continue their operations. This conclusion is consistent with conclusion IR-1 from the ONR’s Interim Report i.e. “In considering the direct causes of the Fukushima accident we see no reason for curtailing the operation of nuclear power plants or other nuclear facilities in the UK”.
The EU Stress Test Reports also raise ‘considerations’: these are defined as ‘Opportunities to further examine potential enhancements to plant, process or people for beyond design basis scenarios’.
Don't like a link to EDF? OK, here is another one...
A report by the UK here is interesting:
http://www.nuleaf.org.uk/nuleaf/doc...m_9_UK_Response_to_the_Fukushima_accident.pdf
Dr Weightman’s final report found that:
• There is no reason to curtail the operation of UK operating sites, although operators should continue to follow the founding principle of continuous improvement.
• There are no fundamental weaknesses in the UK nuclear licensing regime or the safety assessment principles that underpin it …
• The final report also confirms Dr Weightman’s advice … that he saw no reason to revise the strategic advice given by the regulators on which the Nuclear National Policy Statement was based, or any need to change present siting strategies for new nuclear power stations in the UK.
• The UK practice of periodic safety reviews of licensed sites provides a robust means of ensuring continuous improvement …
• The events at Fukushima reinforce the need to continue to pursue decommissioning of former nuclear sites with utmost vigour and determination.
• The regulator is satisfied with the responses and plans initiated by the Government and nuclear industry in response to the interim report.”
Given that newer reactors are less complex generally, and benefit from even safer designs, I see no reason why we should be worried.
Its just not your day is it.
Still no evidence from you I see, just assertions (mud slinging).
That other sites are over budget on a project is not suprising with a new design. Such a project will give lessons that can be learnt for the next build, and so on. As I have already shown, future nuclear builds work out cheaper when you stick to a single design for multiple plants (history shows this). I have even given the numbers that can be save for future builds in a previous post. This concept is not without precidence.
This is why the Government decided to not build the Seven Barrage, as it would be a one off build.
