We have a hallway or passage from the kitchen to the front of the house. Relatively narrow, and the ceiling's only 7'. It's currently lit with a pendant which is unsatisfactory as the bulb's not much above eye level, and you couldn't fit a shade without it being too low. From my rough notes the passage is just under 5m by just over 1m.
What's the best way to light this sort of space? It doesn't need to be too bright, for example a 5W CFL in the current fitting is just about OK.
Looking for ideas for a quick fix, I thought of a drum bulkhead light on the ceiling in place of the rose, but these seem to take 28 or 16W tubes which will be too bright - can you fit less powerful tubes in this sort of fitting?
Thanks,
Tony S
Thanks,
Tony S
