You sure it wasn`t 300 ohms?, what wattage is the element?.
Why not?Resistance L to N of 0.3Ω isn't possible.
I'm taking it to be open circuit with a reading of '1'If you are getting a closed circuit between Live and Earth, that does not sound too good!
How can the filament resistance, L to N, reduce to 0.3Ω if, as I think, L to E is open circuit?Why not?Resistance L to N of 0.3Ω isn't possible.
Unless they make a noise, all electric heating elements are as efficient as each other - 100% of the energy they consume is turned into heat.Its a 300watt PTC energy efficient heating element...
L-E is supposed to be open circuit - it makes towel rails a lot safer.How can the filament resistance, L to N, reduce to 0.3Ω if, as I think, L to E is open circuit?
Your element should be 180-200Ω.
That's what I meant - as it should be with no shorts.L-E is supposed to be open circuit - it makes towel rails a lot safer.How can the filament resistance, L to N, reduce to 0.3Ω if, as I think, L to E is open circuit?
Yes, faulty perhaps but how does the resistance reduce causing overload, let alone by such a huge amount?L-N is 0.3Ω because the element is faulty, and the 800-ish amps it draws is popping the fuse and tripping the circuit breaker.
There is no short to earth - there doesn't have to be for there to be a short from L to N.That's what I meant - as it should be with no shorts.
I don't understand that. What do you mean how does it reduce causing overload?Yes, faulty perhaps but how does the resistance reduce causing overload, let alone by such a huge amount?
Ah, you mean across the terminals or conductors - not through the filament.There is no short to earth - there doesn't have to be for there to be a short from L to N.That's what I meant - as it should be with no shorts.
As above.I don't understand that. What do you mean how does it reduce causing overload?
It must be well made.I'm a little surprised that the first application of power didn't vaporise the fault, but there ya go.
It could be through the element - it could have a short close to the two ends of it.Ah, you mean across the terminals or conductors - not through the filament.
I wasn't thinking of that.
My apologise that does seem to be the case.I'm taking it to be open circuit with a reading of '1'If you are getting a closed circuit between Live and Earth, that does not sound too good!
No, the resistance of the filament reducing from whatever it should be to 0.3Ω.And you asked, in effect, was "How does the resistance of 0.3Ω between L & N reduce causing overload, let alone by such a huge amount?".
Sorry - I still have no idea what you mean.
