Before I start Im not going to attempt to wire into the mains myself! I know how to wire a ring and lighting circuit but no way am I confident to play with the mains or risk the house!
Im intending to start building a summerhouse/workshop in the next month or so and wiring it for electric.
The summerhouse is going to be my escape at the end of the garden when her indoors gets on my case!
I also would like to use it for entertainment. Electrics wise in the summerhouse it would have 2 ceiling lights, 9.5kw water heater and a ring consisting of maybe 4 double sockets to run a tv, stereo and what ever other crap I will end up plugged in!
The workshop part would have 4 double sockets and 1 ceiling light. Wattage is a hard one to guess as with power tools it could be a few hundred to a few thousand watts!
Now you have what I want to do I'll give you the questions!
I've read from other threads on various forums I'd be best putting a switchfuse from the mains supply this for example http://www.screwfix.com/p/wylex-100a-switchfuse-100a-cf/60830
Run some armoured cable from the house to the SH/WS thickness depending on the electricians calculations, and connect to a consumer unit like http://www.screwfix.com/p/wylex-11-way-fully-insulated-main-switch-consumer-unit/26208
How 'correct' is this?
Would these be the correct parts for the electrician if I was to purchase them for him?
The summerhouse /workshop will be approximately 50ft away from the house if that makes any difference?
Am I correct in thinking I can install all electrics in the SH/WS and then get them passed off by the electrician and he just hooks up the supply?
Attached is a photos of the house supply etc
