- Joined
- 9 May 2014
- Messages
- 8
- Reaction score
- 0
- Country
Hi
I have search the forum and have found information regarding 13 amp ovens but not 2. I wanted to clarify something to make sure that my electrician is correct.
We had an existing 6mm cable which connected to 1 electric oven. This oven has been pulled out and we have replaced it with 2 ovens rated at 2300W or <13 amp.
The circuit is alone and only 4m from the CU so i know it has enough juice to power both ovens. The electrician has used the existing isolation switch and attached a 2 plug socket to it. He intends to attach 2 plug heads to the ovens and then just plug them straight in. The oven guide says they have to be hard wired in although 13amp plug seems right to me as the max is under 13amps.
Question I have is with a fuse at the isolation point and a mcb covering it at the CU, what are the chances that the fuse on the socket will blow? The sockets are plugged behind the ovens, I dont want to find myself in a situation where i am finding myself constantly ripping out my oven to get to the sockets if theres a failure somewhere. Does the fuse on the isolation unit blow first?
Thanks in advance.
Thanks in advance.
