2 way switching - connecting lamps at both switches
22 Jan 2012
UK
I feel a bit silly for asking, but I can't figure it out.
I have a situation with 2 way switching, 3C+E between the 2 switch points.
Is it possible to connect a lamp fitting directly to each switch and have the system work? Can the COM strapper be used as a neutral? I think it can, but would like to clarify!
I think I have seen a similar setup once before but I cannot totally remember.
Thanks for any help.
You cannot use a strapper as a neutral.
What do you think would happen when you switched the power back on?
It would be possible to do what you want only if a neutral was available at the switches - or at the light position but then you would not be wanting to do it.
I rushed back to my laptop to change the bit about using the strapper as neutral as I quickly realised it was stupid, but too slow!
Yes one of the switches has a L+N feed.
No you can only supply the light from one switch or the other, but not one from each if you just have a 3 core between the two switches.
Thanks.
Can you explain how the setup in a hallway works (Mine included).
The power is supplied by the downstairs switch, but the lamps are connected via the upstairs switch. There is just a 3C+E between them, no borrowed neutrals.
I have looked at the wiki, but I can't see an example of this setup.
I would have said yes, but
Are you sure?
You say there is a neutral at one switch.
Is this downstairs?
Are you sure one of the 3-core isn't already used as a neutral?
Where do you want to connect the new second light?
In your case you have the supply at one switch
and light at the other switch.
2 strapper wires
and 1 neutral
When you have the supply and light at the same switch, you need all 3 wires as lives
Yes definitely no borrowed neutrals
The neutral is downstairs
1 of the 3 cores could be neutral, I think this is where I get lost on this one
The connecting of a second light is not on this setup, but a similar one at my parents place where its not practical to connect from 1 lamp to the next.
2 strapper wires
and 1 neutral
Can you explain that setup? This is what I can't understand, and it's a little frustrating!
Thanks Flameport, thats exactly what I needed to see!
Hopefully it can be added to the Wiki.
So I now need a new plan for their place... likely running either an extra neutral from the same circuit, or a T+E between the lamps (Although that will be an absolute nightmare).
There may be a standard wiring method but it is not the only way to do it.
Can you show me an alternative method then please ?
Yes but that doesn't say where the thermostat wires go.
Why not? The white valve wire selects heating on, therefore that is the output of the new controller.
I don't know how, but it seems you have managed to quote into the wrong thread? Very strange!!?
