The building owner deciding they don't really like them would not be enough to get exemption. There used to be a standard form to complete.
I did a google and found that Vokera do one. Probably others but they never showed up on Google.I had a really good case for getting an exemption a few years back. Unfortunately what stopped me was that I couldn't get hold of a non condensing boiler. Don't know of any manufacturer producing one. Why would they?
He doesn't want a plume pipe on the ceiling of the landing. That is that. So an exemption or go all electric.The building owner deciding they don't really like them would not be enough to get exemption. There used to be a standard form to complete.
Thank you. On page 69 the flow chart clearly states a non-condensing boiler can be fitted.Page 69 onwards http://www.planningportal.gov.uk/uploads/br/BR_PDF_PTL_DOMHEAT.pdf. As has been said though, you won't get an exception just because someone doesn't like the look of a flue.
I rang up after posting to confirm. They will not have ugly pipes on the landing, that is understandable. The existing boiler discharges onto the landing at high level. A plume would be a nuisance. It is the freeholder's building and he will not have a plume or a big pipe fitted no mater what I think or want to do.In your first post you said that the building owner MAY not permit the fitting of a condensing boiler......Now you say that he WILL not allow it... Which is it? A condensing boiler can be fitted... The owners objections do not change the fact that one can be fitted so there can be no exemption....Looks like you're gonna have a cold Winter..
How does the existing boiler discharge its products of combustion? where does the flue run?
The flue exits onto a common open landing. A plume there would be a problem.
Is that your only external wall?
Otherwise the plume on the landing has to be tolerated unless a flue extension kit can be used.
There is no personal choice on my part. I cannot have a plume or a pipe in the common landing - FULL STOP. I am prevented from doing that. It is NOT my property to run a pipe in. If I tried to fit an extension flue pipe the freeholder would come and stop it, and I do not blame him as they look awful.Someone's personal choice does not give grounds for exemption. Its a law rather than someones personal foley.
Apply at your peril, if anyone comes out, you'll wish you hadn't done it.
If it was me.... I'd just fit one and not say a word.
You are right, I cannot ignore building regs on anything inside my flat where I have control. The freeholder cannot ignore building regs on the parts he owns. He does not own my flat and I do not own his landing. I only have the right to walk down the landing, no more. What he does with his landing is his business, and I have no right to do anything to his landing, no more than I can run pipes or cables through next door's flat.Does your lease agreement give you permission to ignore building regs?
Does it give your landlord?
No.
Aesthetic preferences are not a factor for either of you.
Unless the building is listed or in a conservation area.
I did check with him. He was emphatic that no pipe will be run on the landing.You might want to ACTUALLY check with your local council. Rather than trying to interpret things yourself.
