Seems to me that some/most of these installers aren't even qualified electrically. British Gas have a load that raise issues whilst checking boilers
I'm still not clear as to what it is that requires, or may require, clarification.Sorry john, it is a question, which i would appreciate clarification on, however, i am happy to ponder as i have the time.
A whole load of "yeah, but" stuff.
Guys - get a grip.More "yeah, but" stuff.
That reason is completely ludicrous and shows total ignorance on the part of the installer.
... they employ stupid, ignorant, unqualified and incompetent people to do the installations ...
Small ovens do.Does the stove come with a plug?
Usually a 6mm² cable and 30A fuse or 32A MCB.What is the standard or range of branch protection device used on a UK stove?
When you say 'plug in', we only have 13A plugs in domestic properties.Maybe these are stupid questions but I am having a hard time understanding why a new residential stove will not simply plug into something existing.
Let me ask a slightly different question then.
Yes they do.Your questions have nothing to do with this thread
They are about UK installationsYour questions have no relavence to UK electric installations
PLEASE take your questions, as a separate topic, and post them on the Electrics OUTSIDE the UK Forum.
http://www.diynot.com/forums/viewforum.php?f=9[/QUOTE]
Why is that forum a good place to ask about UK rules/practices/environments?
I disagree. It seems perfectly reasonable for them to refuse to install an appliance if aspects of the fixed installation are such as to affect safety relating to the appliance. One can obviously debate how far that should go, but, for example, I think it would be reasonable to refuse to install if the fault protection of the available circuit was significantly inadequate, and certainly if there were no earth continuity at all.Guys - get a grip. ... This is an APPLIANCE - it is 100% irrelevant what is going on in the actual fixed installation from the POV of "am I allowed to install this?".
No - it is neither plugged in, nor connected to a ring final.The Cooker is " plugged " into the kitchen ring then?
You can't, entirely, unless you have very few major appliances.What I find hard to understand is how you could wire a modern UK kitchen on a 32 amp ring.
Unless you have a gas cooker, which only needs power for an igniter and a light, you would have a dedicated radial circuit for an electric cooker, or an electric hob. A small oven, or a small dual-fuel cooker with a gas hob and an electric oven might be able to be plugged into a socket circuit, although the whole issue of plugging loads >2kW into rings is contentious.You must have other dedicated circuits?
In the UK no domestic appliances are supplied with any plug other than a BS 1363. It it can't go on one of those it will always (well, 99.999...% of the time) be hardwired. FYI, here a 40A cooker circuit could support a 25kW beast.My stove is plugged into a Nema 14 50 ( but protected by a 40 amp breaker because that was the original breaker and this is acceptable by the CEC rules ).
Alternatively I could have hard wired it to the 40 amp CB with AWG 8 and removed the factory plug.
No such rules here, but personally I think a dedicated circuit for F/F is a good idea.Also on their own circuits are my fridge ( dedicated circuit rules for this appliance as well as microwave and dish washer ).
7.68kW. A lot for a laundry appliance, or microwave. Plenty for a cooker, even a large multi-oven one, after diversity is considered. Not really enough for a shower.32 amps at 240 volts is a considerable amount of power mind you.....
No - our requirement is that the design load must be ≤ the rating of the breaker or fuse which in turn must be ≤ the current carrying capacity of the cable. So we could have a 32A load on a 32A circuit using cable rated at 32A.( can I assume you also have a rule to the effect of no more than 80% load factor on a circuit there too? ).
