I can't answer that (although, as you say, it would be a bit surprising) but, if woodscrews have been used (effectively as self-tappers) the original thread may be no longer recognisable, or usable - so maybe self-tappers are the most pragmatic solution, given what has probably happened to any threads which may originally have been there??Are you saying that merlin originally used self tappers (would seem rather crude for a high end brand like them) or that you would use self tappers in a repair because you couldn't be bothered identifying the thread?
A couple of hours ago, RF told us that Merlin Gerin (not Hager!) have always used self-tappers. There's therefore presumably no thread to 'match up', other than the one created by the original self-tapper.I think it is the OP that cannot be bothered Identifying the thread, not RFL! ... Surely cannot be that hard doing onsite matching up?
A couple of hours ago, RF told us that Hager
Whoops - now why did I write that?!! Corrected.HagerA couple of hours ago, RF told us that Hager
That all makes sense.I think no 8 would be better in an ideal board. However if hole has been enlarged then a no10 could be a better choice and the flange head more in line with what was original. ... as mentioned earlier the existing style ones wlll still be present to compare and test run the holes
