The equipment can be hired, if you know how to use it and how to interpret the results.
The problem with the Wiki on this site is that it is fundamentally broken and unusable.I remain happy to fight with the forum software, but would only be prepared to do so if there were something approaching a consensus about content.
That's one reason why some DIYers ought not to do some work.So that's why people don't do DIY Electrics, they won't have the equipment to do the test.
Not "no one". Maybe the system doesn't like youThe problem with the Wiki on this site is that it is fundamentally broken and unusable. .... yet the login and register links are still broken and have been for years/ever, meaning that no one can actually add or edit content, totally negating the whole point of it existing.I remain happy to fight with the forum software, but would only be prepared to do so if there were something approaching a consensus about content.
Why ever not? How many electricians would refuse to carry out a periodic inspection because the installation is somebody else's work?Speak to your electrician first, as he might not be happy with testing someone else's work.
But it wouldn't be a Periodic would it? It would be an EIC.Why ever not? How many electricians would refuse to carry out a periodic inspection because the installation is somebody else's work?Speak to your electrician first, as he might not be happy with testing someone else's work.
Not if someone just asks you to inspect what they have done.But it wouldn't be a Periodic would it? It would be an EIC.Why ever not? How many electricians would refuse to carry out a periodic inspection because the installation is somebody else's work?Speak to your electrician first, as he might not be happy with testing someone else's work.
I've seen in Wilkos (!) socket boxes with a large cutout that screw into the existing backbox and/or the wall and take a normal double socket. Much better
Carry out an earth fault loop impedance test to ensure your socket will disconnect in the event of a fault.
Test the RCD (if your consumer unit has one) will disconnect in the required timed.
Most diyer's will have neither the equipment nor the knowledge to carry out and understand such tests, and while that would mean their work would not be complying to BS7671; one is not that likley to make the Zs worse that what it already is by doing a simple swap of a socket providing that they are careful to ensure a good earth connection. Of course that does not rule out that they could make the Zs far worse by a multitude of ways and thus create a real danger by casing a ineffective earth; and how many DIY'ers over the year have replaced a light switch or light fitting say without complying with BS7671 but also at the same time by good luck have not impeded the Zs.
Now a proper calibrated Earth Loop Impedance tester is better than this, just as this is better than a multimeter, and just as a multimeter is better than nothing.
