Again, back to arguments about what constitutes reasonable, given the way the building regulations themselves are worded. If I need 400W to provide adequate illuminatation over a given area for my purposes, I would argue that it's reasonable. Of course, it may not be so reasonable if I were to leave that 400W on at times when I didn't need the illumination.Yes, it's the Approved Document which actually gives recommended figures, but Part L itself requires that there be reasonable provision for the conservation of power - and a 400W floodlight in domestic property might well be considered not to constitute such reasonable provision.
But that's rather academic anyway - Who would be crazy enough to involve the local council just to add an exterior floodlight? Besides, surely it's not notifiable work anyway, unless being provisioned on a new circuit?
Which was really my point. Are regulations supposed to be a set of rules developed by those who (supposedly) are competent to draft them as a minimum standard which must be achieved, or are they supposed to be a vague "do what you think best based upon your own knowledge and experience" suggestion? If the former, then they need to cover all situations in as near-complete detail as possible, although obviously that's an ideal which can never be fully realized in a changing world. If the latter, then why do they still contain certain very specific "thou shalt" and "thou shalt not" instructions?In some senses you're right, but that is not the nature of rules, regulations and legislation. Apart from anything else, in the absence of detail, any accusation of failure to comply with a 'bottom line' regulation such as you suggest (which is very similar to Part P) becomes a matter of opinions.
