- Joined
- 11 Jan 2015
- Messages
- 93
- Reaction score
- 0
- Country
Is the plate screw on that socket screwing into the brown wire that is positioned behind the screw lug?I've ony changed one of the sockets so far, wired up exactly as the last one was.
You can either fit all the earth wires from the back box earth terminal to the switches earth terminal. Or run a 1.0mm² earth wire from the back box earth terminal to the earth terminal on the switch.Can I earth the metal plate using one of the earth wires at the back of the box?
I don't think the plate screw is screwing into the brown wire, there's no evidence that it is anyways.
As for the earthing of the switch, if I connect all the earth wires to the switch that would then leave none attached to the back box. Is that right? I thought one had to go to the back box as well?
