hi
First time poster so be nice please!
I want to install a Triton T40i - it's basically a shower attachment with a booster pump, no heating element etc, it's kind a of a one off product from what I can tell.
Reading the instructions (http://www.tritonshowers.co.uk/media/custom/upload/File-1424097751.pdf) and noting page 5 it says this can be fitted using 1mm2 wiring to a 3AMP double pole switch. I'm guessing as its only a pump no heating element etc that's why it can be done this way. I could be wrong.
So I plan to use a plug socket located outside the bathroom in the airing cupboard, remove the socket and use those incoming live wires and put them into a 13A RCD Fused Spur - but change the fuse to 3AMPS and put a note to say MAX 3AMPS.
Then using 1mm2 wire from this 3AMP RCD put the wire into the loft and back down into the bathroom and into the back of the shower.
The key question I'm asking here is - is it safe? My neighbor actually wired their one into the extractor fan wiring and removed the extractor fan and its been going for years, but I don't want to do that.
I know a competent electrician should be used but I feel that this may be something I can do, so any advice would be appreciated. If it any point I feel like this work is beyond me then I will of course get help. Also, I'm guessing I have to notify my council and then get this work signed off.
Thanks I'm advance!
Thanks I'm advance!
