Actually, moving it up a bit as well would be jolly useful, as I've got to run a water supply through that space, i.e. along that wall under the stairs, and out into the hall.What no space above the old service pipes ether as that is where I meant
Guess its just too hard to actually listen to advice and keep asking what if questions instead of just phoning up and getting it moved by the proper people for nothing because its too close to electrics
OP: it really is that simple... Grid owns the meter. It is too close to the electrical gear and is not to regs. As it is evident that it came after the electrical install, it shouldn't have been put there and needs to be moved. Grid have a duty to make sure it complies... Call them and get them round, they shouldn't argue, but might... Argue back![]()
Grid will move it though providing its not a 3rd party meter which that one isnt
Well - I will certainly investigate getting it moved FOC, as that would be ideal.Guess its just too hard to actually listen to advice and keep asking what if questions instead of just phoning up and getting it moved by the proper people for nothing because its too close to electrics
Then it is rather academic. But yes on most counts.
Just make sure your registered engineer has his meters on his card, it needs a floor bracket fixed to the floor. your gas pipework wants to be rerouted so it does not cross the electrical stuff.
yes can be done, no biggy
as for moving that meter by 10cm, I see no problem with that flexible pipe reaching it as long as he gets an approved contractor to shift it.
might as well let the rgi move it for u at the same time as boiler
Worth a try. I would expect them to say they didn't put it there so they aren't going to move it for free, but what do I have to lose?OP: it really is that simple... Grid owns the meter. It is too close to the electrical gear and is not to regs. As it is evident that it came after the electrical install, it shouldn't have been put there and needs to be moved. Grid have a duty to make sure it complies... Call them and get them round, they shouldn't argue, but might... Argue back![]()
Sorry - I thought you meant to over the electricity meter.
Yes, there is space above the old pipes:
But it couldn't go very far up before the flexible pipe becomes a limitation - probably not far enough for it to make any practical difference.
And wherever it is the pipe on my side has to go off to the left, as that's where the gas is needed, so it's always going to have to cross some electrics. The white board in the top left corner of the photo has the CUs on it, and when I find my round tuit and do the electrical changes I want then the spaces to the left of the meter and above it will have switchgear in, so the way to avoid most of the electrical services is to keep the pipe as low as possible.
And anyway - I'm not not listening.Guess its just too hard to actually listen to advice
I'll drop them an initial email enquiry over the weekend.Don't pay an RGI to do it, your supplier should move it for you, BG will move it for free.
That would be good. The reason I've focused on keeping the flexible pipe as is is a (possibly uninformed) notion that not fiddling with "their" pipe makes life simpler.Personally, I prefer meters attached the wall, so i'd be inclined to mount it on the wall with a hard pipe inlet instead of the flexible one you have now.
The space above is earmarked - basically the shaded area in the photo below will be full of stuff:The outlet pipe work would need to be routed up and above the electric meter.
The cable in the first photo in my first post isn't connected yet - when it is it will run in the trunking up against the stairs.If you didnt want the meter mounting, and that cable to the right can be moved, fitting the meter and re-routing the pipework isn't really and issue either.
