- Joined
- 1 Apr 2016
- Messages
- 180
- Reaction score
- 1
- Country
Because you apps like an old woman moaning about not being helped.
I'm not moaning I'm just pointing out that you were being deliberately unhelpful. When I asked if you knew the answer to my question you just said 'yes thanks'.
It doesn't encourage working on the boiler. It is describing stand alone vessels.
It mentions the PV valve is in or around the boiler somewhere. It doesn't say anything about not removing the cover. Maybe they should make it more clear that you are not to remove the cover.
PICK UP THAT DAM PHONE !!! stop messing with that boiler,![]()
I've ordered a new diverter valve and also a new AAV as it has been leaking fluid. I will be fitting them myself when they arrive. As long as the cover is replaced properly and I am not messing around with the gas side of things I really don't see the problem.
