- Joined
- 27 Jan 2008
- Messages
- 28,386
- Reaction score
- 3,452
- Location
- Country
This came up before. Seems they don't work. Some one on this forum tried it.Philips LED 12v lamps are quite happy on almost all 'transformers'. Apparently they used some clever elektroniky stuff to make them work even on devices with a 20va minimum loading.
Although likely a 12 volt DC power supply will work, if you can return bulbs then I would consider converting to low voltage and remove all transformers. This "Driver" will power up to a 10W LED lamp at £8.40, or whole new fitting sample here at £4.56 is it really worth staying with extra low voltage?
