- Joined
- 3 Jun 2016
- Messages
- 141
- Reaction score
- 4
- Country
I'm going through the process of buying a detached 1930's property which has a fairly typical roof with no felt. The report said a few tiles had slipped and there was a few bits of light that could be seen in the loft.
I went with my father to take a look in the loft, my father used to be in the building trade but not a builder or a roofer. He said externally the roof looked in good condition, no sag, tiles looked fine. On entering the loft space it was fairly obvious that it was dry, is was very very dusty but in the main looked to be in not too bad a condition. There were however loose plastic sheets in various places that had been stapled to some of the rafters and on first sight I thought they were sagging due to water lying in them, on closer inspection it was dust from the crumbling mortar (tourching ??? only on the edges not full covering) which was on the end of each row of tiles. All the mortar was crumbling away badly and a lot was on the loft floor, mainly on the old insulation.
So in short I suppose a fairly typical 1930's no felt roof.
I'd like to remove the dust, put new insulation in to the loft, have some boarding to put a few things in the loft and obviously ideally not have to deal with continued dust from the mortar but I'm guessing I might be stuck with that.
Now having a read around it sounds like using foam internally is a no no, stay well clear. In general people say if there are no leaks, don't touch. Is there a simple way though of adding an bonding agent on to the mortar that is still in place but crumbling, or if I remove the mortar is there an alternative material I could use to replace it, for instance a quick squirt of foam (not a full covering), something just to hold the tiles and keep some of the potential blown in rain out.
As far as I can see the tiles are held in place via the nibs and there own weight. Does the mortar much help with keeping the tiles in place and if it does should I be worried so much of it has crumbled away.
So basically I'd like to make sure the risk of leaks is minimised, reduce the dust, clear out the existing insulation and add some new and put some boards down, but I'm concerned about the state of the strips of internal mortar on the end of each tile and how I deal with this problem.
Thoughts ?
And thanks in advance
Thoughts ?
