I'm looking at a Honeywell G4 metal control panel. It's the 8SP419A-UK, and I'm confused. I've gone through the entire engineer's manual and can't work out how to connect door /window contacts. There are eight security zones which feature two connectors each. There is also just one pair of connectors for tamper.
I thought that these days panels had shunt and end of line resistors. I can't find any mention of resistors in either the text or wiring diagrams. So my problem is how do you provide tamper detection to the zones on this panel? If you use the tamper pair of contacts to create a single huge tamper loop for all of the contacts for eight zones and the PA, the metal enclosure will be full of spliced cables and electrical tape. Seems like that would be a total mess and doesn't seem like the correct approach.
Am I totally confused and missing the obvious? Does this panel not use resistors?
