I received a quote for the following extra work (on top of a quote to fit new smoke/heat alarms, EICR & PAT tests, Instal new RCD consumer unit, Instal extractor fans in kitchen and bathroom):
They are also only going to use existing or new trunking or try to feed through existing holes in walls etc for the job so no plastering over etc.
The flat is completely empty and they have as much time as they need to do within reason.
The quote for just the extra work is £600. Is this over priced bearing in mind that it's only a partial rewire and it should only take realistically max 1 day for the electrician and his helper to complete the rewire? I can't imagine materials will be that expensive given that I'm already paying separately/additionally for the new RCD unit.
- Replace/rewire old VIR/VRI cable to 7-8 light sockets, 1 cooker and 1 water heater.
