hello
looking for a little advice.
just purchased a ex council flat and looking to have the boiler moved from a cupboard in hall way into the kitchen.
i know i will need a reg installer to do this but other issues to be addressed first.
the flat has a porch and this is where the gas meter is, the pipe is under the concrete floor then comes into the property in a different cupboard facing the boiler one. it runs at ceiling height along this cupboard into a void where the old hot air heating was then it runs along ceiling over living room door into kitchen along ceiling into back of cupboard that currently houses boiler then run back out this cupboard behind kitchen units to cooker point.
i want to have the pipe running from meter under floor in porch into hallway under the concrete floor there straight into the cupboard that housing boiler so then can have clear run into kitchen for cooker and boiler.
so i want to do the ground work for this by creating the trench any ideas on how deep does it have to be ??
is there a different depth for plastic, copper, steel pipes??
i will be getting a registered fitter to do the job but want the ground work ready for him to come do the pipes and go so i can refill and carry on
cheers
cheers
