hi, new to the forum and hoping someone can help.
I've had a new boiler fitted but it won't run, plumber has said the boiler must be faulty but I'm not sure? I have been reading up and I'm not sure whether he has wired it up correctly. He has wired the live, neutral and earth from a socket into the main pcb, and then wired the controller (2 channel programmer) feed into the same block on the pcb, does anyone know if this is correct as the manual states 'provide one common supply for the boiler and the corresponding controller?
Many thanks for any advice
