Bedside light switch wiring help
6 Nov 2008
Can anyone help me with the wiring in my bedroom.
We would like to add a two gang two way light switch either side of the bed. One of the switches on either switch to turn the ceiling light on/off & the other switches to turn the wall light above bed on/off.
I have attached a diagram. Hope it makes some sense?
It's unlikely you will be able to take the supply from a switch as there probably won't be a neutral.
You will need to take the supply from the ceiling light or a socket.
So you have the switch cable in place and live and neutral feed??
So what is your problem then?
Two way switching with an intermediate switch, simples!
I just want to make sure the wiring is correct for what im trying to achieve
I guess ther intermediate would be the main ceiling switch as its one gang & the others are two?
There is a supply at each switch.
Really? OK. You don't need all of them.
Consider the two lights separately. For the ceiling light:
2-way switch at left bedside -> 3-core cable -> intermediate switch at right bedside -> 3-core cable -> 2-way switch at door.
Connect the supply and the cable to the ceiling light at the door switch.
For the wall light:
2-way switch at right bedside -> 3-core cable -> 2-way switch at left bedside.
Connect the supply and the cable to the wall light at the left bedside.
This site's wiki has diagrams showing more detail for the 2-way and intermediate switch connections.
As I've described it above, you'll need a switch at the right bedside with one 2-way and one intermediate. That might not be easy to find, except using a "grid" or modular system of some sort. 2-gang intermediate switches are available, though a bit rare, so you can use an intermediate switch as a 2-way switch by ignoring one of the terminals.
Someone above suggested that the intermediate switch could be at the door, but I can't see how to do that with your wiring.
Edit: it seems there are switches with one intermediate and one 2-way:
https://www.tlc-direct.co.uk/Products/VLXDQ71S.html
For the wall light:
Many thanks. Very helpful.
