Wonder if those mbars are OK?
just out of curiosity, did they perform the flue analysis and did they give you a little print out or told you if all the readings were Ok and within the required limits? what was your CO reading? this is just out of interest as I had mine serviced yesterday and the RGE gave me a print out of mine which said the following :
O2 %: 12.6
CO (PPM) 1
CO2 % 4.7
Ratio: 0.0000
pressure mbars 0.04
You would love that wouldn't you! but you are too late for that, I have already been ripped to shreds by another one of your gang member and I am solo!be fun watchin Steel take him apart quicker than he can spell google![]()
On the serious note yes that is the figure printed exactly as it is, RGE said that even 1ppm was going down to zero, and is on full heat, boiler was giving me explosive ignition, so i booked him to have a look what was wrong, he found that my burner pressure had crept up to almost 10mbars from the reccomended for my boiler (Vaillant 221GB) of 6mbars. he re-adjusted that and carried out low gas pressure test on low flame, he had to disconnect a certain rubber tubing from air pump and did then he set the low gas burner pressure. Having said that he checked incoming gas pressure as well, with my cooker all 4 burners on full heat and said the incoming pressure was within the limits.put it this way 0.0000 my ass , as your ratio would more like 0.02 , is that your high rate results ,not as healthy as you thought . steel has the nose for bullsh!tters![]()
So the combustion chamber/heatx was reported to be in good order with no signs of water pooling (condense) or rot???..Vaillant 221GB I run it at very low flow temperature of 40C.
Great idea ,now here's what you do......if assuming Co is only 1PPM, then I should be able to bring back the flue gasses and heat my house with 100% efficiency, now what do you recon? do you think it is a terrific idea?![]()
I always wanted to do that, I don't know why, but yes one day not too soon, I will and post results as to how much efficiency i have gained, I also wanted to test my CO detector, so i took it outside and exposed it to my flue, 2 minutes later it started to drip with condensation, yet it did not go off, and showed 15ppm, I have an amazing boiler I tell you Steelmasons, you will definitely envy it. Its never been topped up with any chemical cleaners, or power flushed, and the rads are from 1975! you could seriously drink the CH water as a vintage wine! its that good!Great idea ,now here's what you do......
Get hold of some 50mm copex tubing and attach it to inner flue @ terminal , run the tubing into the house through a window and let us know how it goes...Oh and while you're @ it crank boiler stat to max setting (No 9)..
Can't really blame her considering your ongoing sex change...anymore treatment to be had or are you all woman now??... It must of been a hard battle for you..The ex is rinsing me.
Yeah pretty good cheers.
I had to liquidate my plumbing firm so now I've started working for the Serious Fraud Office investigating people who advertise themselves as a LTD company when they are not. It's shocking that people deceive consumers like that.
Some hefty fines being handed out.
