2" diameter lights are about the size of the business end of a Maglite torch.Why not?
Simple answer - either use good quality integrated lights, which can be dimmed and are efficient. Or use ones where the power supply and the dimming control is not built into the bulbs.As to dimmable, good quality lamps have pulse width modulated drivers built in which auto correct volt drop, so will not dim, poorer lamps have a simple capacitor to reduce the current so can be dimmed, however those cheaper lamps are going to give around 70 lumen per watt, against the 100 lumen per watt for the better quality.
I agree, however I also don't like spending money, so I have cheap 70 lumen per watt lamps in my house, to date I have renewed some G5.3 MR16 LED lamps, no others have failed, but when I went to CFL I read how they should last 10 years and they did not even reach two years, and it may say 10,000 hours and you may only use it 2 hours a day, so should last 13.7 years, but try going into a shop and say I got this bulb 5 years ago and it's failed, and lets see you get a replacement?Simple answer - either use good quality integrated lights, which can be dimmed and are efficient. Or use ones where the power supply and the dimming control is not built into the bulbs.
The transformers also keep failing on them so moving to LED lamp holders instead with no transformers.
If they keep failing they are NOT transformers, but switch mode power supplies. Transformers are extremely reliable.
When I say failing, I mean they often dont come on for weeks, then suddenly the spot will come on for no reason and go off again after a while. I was told that the transformers are the likely things that go for the MR16 halogens. We had these installed back in 2002.
