The mind boggles. Flickering light when you touch it? Loose wire (or just possibly a bulb about to give up the ghost). Fix that before something sets on fire. The other lights are out because your rewiring, presumably of lamp 2, is incorrect and all the other lights are now connected to the switched live in lamp 2, or perhaps the neutral to the lamp return. Or maybe the live wire isn't even in the block properly, I see metal sticking out in pic 2. Green goo on one wire suggests it may be on others, possibly on connections that are not as obviously visible as a light switch on the wall. Have you fixed the connections on lamp 1 yet? This is why everyone is frustrated and snapping at you, you keep skipping merrily over things that are at best dodgy and at worst dangerous.
