Looking for guidance on replacing existing switches in our kitchen with some LightwaveRF ones I've bought. (LW420 Dimmer (2 gang) & a LW450 2-Way Dimmer (1 Gang))
It's a bit confusing as it uses a signal wire and if wired up incorrectly could kill the switches.
Would it be a problem using the existing wiring that is in place?
Existing Layout:
Right side wiring(1): (I should have got better pics, hopefully these will make sense)
Right side wiring(2):
Right side wiring(3):
Left side wiring(1):
Left side wiring(2):
LW450 2-Way Dimmer (1 Gang) - To replace existing left switch
LW420 Dimmer (2 gang) - To replace existing right switch
The back of the two LW switches:
Thanks up front for any help or advice!
Existing Layout:
