Full set "A" , night set "B" e.g. Landing area A only all others A and B
No leds as default( longer battery life ).and you have been messing with the code programming !
No ...
Did you clean start the panel ? If so what version , if not you should be able to set B unless you messed with user code setting.... best way to check is go into manager menu /.codes / add new user set as example 1960 as code now press yes to All options , come out of programming , now try that code .... can you set B?
Which one ? 2000 or 2020
