Pyronix - Enforcer V10 Install Help
Hi guys,
Just notice when I set the system using the control panel I enter my code and it starts to set Area A (full set) straight away. It won't let me press the Area B button (night set) to part set the system?
Using the app from my phone I can part set it no problem.
Why is the panel not giving me the option of of which Area I want to set?
Matt
Also guys, should the bell have any lights/led? flashing when set (or not set). Do these only flash when the alarm is activated?
I've seen a jumper on the bell module that says comfort lights?
Matt
No leds as default( longer battery life ).and you have been messing with the code programming !
No ...
Did you clean start the panel ? If so what version , if not you should be able to set B unless you messed with user code setting.... best way to check is go into manager menu /.codes / add new user set as example 1960 as code now press yes to All options , come out of programming , now try that code .... can you set B?
No ...
Yes did a clean start.
Enabled flex set and all works as it should. Got the remote keypad up and running now as well :)
One thing my old Yale system had was a wireless panic button which was mounted by the bed, can't seem to see that Pyronix do one?
